Latest post 07-21-2007 2:32 PM by joeyboygolf. 7 replies.
Page 1 of 1 (8 items)
  • 07-21-2007 11:10 AM
    9500 connected to Pentas...
    To get the maximum from the displays....what is the suggested best cable to connect a 9500 to some Pentas....??? MK1 powerlink, MK2 powerlink.....Speakerlink?>>>  I've not got the Pentas yet...so i'd be open to Penta 1,2 or 3's.....any suggestions....for maximum compatibility...
  • 07-21-2007 11:37 AM In reply to
    Re: 9500 connected to Pentas...
    You can use speakerlink with MkI or speakerlink or Mk2 powerlink with Penta II or III
    Regards Graham
  • 07-21-2007 12:29 PM In reply to
    Hi Graham....so do i need both???  Speakerlink and Powerlink????
    How would I connect to Penta 1's...??
    Thanks Graham....
  • 07-21-2007 1:09 PM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    I would recommend Penta 3's because they are the latest. Penta 1 and 2 have speakerlinks. To my knowledge BC9500 does not have speakerlink but powerlink instead. BC9000 has speakerlinks.
    To get the display right you need the fully connected powerlink cable (the old thick one). That is working nice with my BS6500 and Penta 2's, which are from the same timeperiod than your BC9500.
  • 07-21-2007 1:28 PM In reply to
    Thanks for the info...so MKII  Powerlink cables to the Pentas....if they are Penta I's, i'll have to use the converters at the speakers to convert the Powerlink MKII to speakerlink and RCA... i believe???
    I'm waiting on the shipment of the 9500 now...and another question...for my TV sound in...does it have RCA inputs?? or will i have to use a DIN (input) to RCA converter..
  • 07-21-2007 1:50 PM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    mecca:
    What I usually do when I have a question about what kind of inputs a system has is first check the user guide. It's available from both this site as well as bang-olufsen.com
  • 07-21-2007 1:53 PM In reply to
    mecca:
    Just DIN sockets.  Works best with a Beovision as it offers AV integration but I realise that this is not available in the US.
  • 07-21-2007 2:32 PM In reply to
    Penta I use speakerlink
    Penta II can use speakerlink OR Mk2 Powerlink
    Why complicate things with an adapter????
    The BC9500 has both speakerlink and powerlink outputs so you can choose either.
    I suggest that you go for Penta III. Earlier models will almost certainly have rotten mid range drivers. Having said that, the midranges could be rotten in III's as well so just factor in an additional £250 + to replace them.
    Regards Graham
