Latest post 07-17-2011 9:10 AM by Z4k26. 5 replies.
Page 1 of 1 (6 items)
  • 07-03-2011 4:50 PM
    • Z4k26
    • Not Ranked
    • Joined on 06-25-2011
    • Posts 4
    Beotalk 1200 powers up bu doesn't recognise the phone line. Please can anyone help?
    • Hello,
    • I have got a Beotalk 1200 and am trying to set it up.
    • I have power to the unit and it looks great, only rob em is it is not recognising the phone line.
    • I have had to use a splitter as I only have one socket in my apartment.
    • I have sent one line to my Beocom 2 PSTN which is working fine, but the Beotalk is not happy.
    • I have tried calling my house line and the Beotalk does nothing.
    • Can anyone help. Maybe I am using a wrong cable? The cable I am using is a standard phone cable, is this correct? If not, does anyone know the right cable to use and what the ref/part number is?
    • Many thanks for any help you can offer.
    • Z
  • 07-09-2011 2:27 AM In reply to
    • Z4k26
    • Not Ranked
    • Posts 4
    Re: Beotalk 1200 powers up bu doesn't recognise the phone line. Please can anyone help?
    Hello, can anyone help?
  • 07-09-2011 3:28 AM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Hi, I have one in a box and just have not got around to setting it up ! Your Beotalk should have a 3 way connecter with POWER LINE APP written on it. I have two of these and the only cosmetic difference is one has a white spot on it. That one is for BT users. If I use it here the Beotalk will not respond to an incoming call.What country are you in?
  • 07-09-2011 5:25 AM In reply to
    • Z4k26
    • Not Ranked
    • Posts 4
    Thanks valve 1. I have the 3 way allotted and have plugged into it and it doesn't work. Maybe its the wrong type though. I am in the uk. Thanks
  • 07-13-2011 7:55 AM In reply to
    Z4k26:
    Dig around on the forum: Keith has posted something on this problem. The wiring in the splitter is quite specific to the Beotalk. You also have to plug it into the primary/ incoming phone line socket, not into a secondary socket.
    When I had a problem with my Beotalk it was a loose connection in the splitter: solved by putting elastic bands around everything!
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 07-17-2011 9:10 AM In reply to
    • Z4k26
    • Not Ranked
    • Posts 4
    Thanks Graham! I resolved my issue today. Quite simple, I went to maplins and purchased a 3m line cord White BT to Rj11. Plugged this in to the secondary plug of a single socket 2way splitter and everything's working fine! Thanks to all for comments and help. Z.
