1st March February 2012
07-15-2011 4:56 AM
Roan Hatfield
- Joined on 07-05-2011
- Bignal End Audley
- Posts 6
Hello again everyone
Just a quick question you may be able to help me with. I have recently acquired a DENON AVR2700 Integrated theatre surround sound receiver, and a set of 5 surround speakers to connect to it , I can connect all the speakers to the unit without any problems but how do I go about connecting the AVR2700 to the T V ,do I need some special cables because the last thing I want to do is to get rid of the T V because its an absolutely super piece of kit it must be one of the best CRT TVs ever produced
I would appreciate it if any of you could help me out
Cheers for now
Roan
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Why do you need it connected to the TV?
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
S-Video + RCA Audio to Scart should do the trick.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
kallasr
- Posts 1,077
Ok, some explanations for Audio Video Reciever.
szenario #1:
an AVR is used as a central hub for audio and video signals.
You can attach all your dvd, bluray, games console etc. to it (the AVR).
The AVR needs a monitor (TV) to show the pictures and speakers to reproduce the sound.
szenario #2:
the AVR is just used to provide the surround sound.
You attach all your gear to the tv (picture) AND to the AVR (sound, coax or digital audio out).
Problem might be a not sychronised picture/sound.
Ralf
PS:
kallasr
- Posts 1,077
Roan Hatfield
- Bignal End Audley
- Posts 6
That appears to be a useful link but its a bit like WAR and PEACE it will take a while to read it and even longer to understand it
Thanks for that
Roan
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
Roan Hatfield:
You will have to excuse my ignorance on these matters but does it not have to be connected to the TV, if not I will probably have to purchase a new DVD player but what if you just want to watch a film on the TV and get the stereo sound .
Roan
The BV3 already gives you stereo sound through its internal amplification and speakers (assuming the source is stereo!).
As regards watching a film on the TV, do you want the original soundtrack sent to your Denon receiver from the BV3 and for the receiver then to process the signal for your full surround system? Or do you want the stereo soundtrack sent to just the front 2 of your surround sound system? Can't see the point of that as the BV3 already does this admirably with its own internal speakers.
Without the necessary internal module in a BV3 for surround sound output, then as far as I know the only signal coming out will be normal stereo which of course the Denon can process and give a surround sound image, but I don't think it will be true 5:1 without the required internal processing in the BV3.
Now over to the experts for the correct answer!
kallasr
- Posts 1,077
Reading your post again - if you just want the sound of the tv (using the INTERNAL tuner of the tv) - no chance!
The tv does not have an audio out....
My earlier explanations are onyl valid if you use a set top box and/or dvd etc.
Ralf
Kokomo
- Spain
- Posts 618
kallasr:
Ralf
Interesting Ralph, I assumed (wrongly?) that one of the scart sockets would be wired for audio out. Isn't this the case? I've never tried it, only for AV in!
kallasr
- Posts 1,077
Yes, you are right, via Scart (to record on a vcr) there should be an audio out-signal.
But for Dolby Surround sound you need a digital/coax out.
Maybe a work-around could be to "grab" the stero signal via scart and create some pseudo 5.1 signal via the avr...
Ralf
PS: Edited, because the VCR gets the sound data via tv signal.... as far as I remember now.
Guy1680
- Joined on 08-18-2007
- Viborg, Denmark
- Posts 104
If the Beovision 3 has the surround sound module fitted, a simple audio out solution may be one of these connected to one of the two 'front' powerlink sockets: (of course the sound will only be stereo, or 'psuedo surround' from the amp's processor)
http://soundsheavenly.co.uk/bando-pltoamp.htm
Probably worth checking if one of the SCARTs provides audio output first. Alternatively there is always the headphone socket....
Roan Hatfield
- Bignal End Audley
- Posts 6
Thanks for that information Guy
I have placed an order for a connecting cable we wil have to see how I get on, I will keep you posted
Thanks again for your comments
Roan
Page 1 of 1 (13 items)
