There is another solution to make a non B&O TV look like a B&O TV.
I did this with my former 52" Samsung TV using a Beovision 1 low floor stand and some custom made fixing solution.
The fixing is a metal frame of heavy quality which can be attached to the holes in the back of a TV (VESA mount) and finally goes into the BV1 Floorstand
Normally the matrix of the holes is 40 x 40 cm which is a VESA norm.
If you're interested, drop me a mail, as I currently sell the floor stand and the fixing solution as I got a 7-40 some time ago...
In terms of the BS9000 stand the TV set is def. too heavy and although the stand will carry the weight it will be very unstable in my opinion.
Best regards
Stephan
