1st March February 2012
Latest post 07-22-2007 4:10 PM by beodim. 8 replies.
07-22-2007 6:25 AM
sveifors
- Joined on 04-16-2007
- North of Norway
- Posts 145
Does anybody now if B & O recommended a certain type of Blank Cassettes. Ferro, chrom , metal etc., What is best or......?
I have a Becocenter 7007 and Beocord 3500
Sveifors
Always look on the B & O side of life
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
When I used to buy blank tapes, I always went for TDK. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Kevin
- Joined on 02-15-2007
- Moderator
- Posts 1,256
Peter:Given the choice I use TDK SA
Very good long lasting tapes I have some 25 years old and still going strong.
beodim
- Joined on 04-17-2007
- Switzerland
- Posts 130
The TDK or Maxell chrome or metal tapes are excellent. As a B&O fan you probably also ought to own a B&O cassette tape (they were produced by BASF, chrome type). They appear sometimes on Ebay.
BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
Mico
- Joined on 05-06-2007
- Finland
- Posts 136
I have not noticed a significant diffrence between brands - maybe the problem is between my ears. Ensure that that the automatics recognize the type you are using correctly. In most cases I used TDK SA-X and MA-X. Nowadays both the BC9000 and BC6500 decks are mostly resting. In 1988 it was always incredible to have 90 minutes of almost uninterrupted hifi playback. LP had typically about 20 minutes and cassettes 45 minutes.
beodim
- Switzerland
- Posts 130
Peter:I think I am right in saying that although Maxell tapes are very good, they have a reputation for being slightly more abrasive.
This is correct. The quality of the Maxell tapes also deteriorated in the 90s, while TDK SA/MA range has always been very good. If Maxell, then go for the models produced in the 80s (still available on Ebay).
Page 1 of 1 (9 items)
