Latest post 06-14-2011 9:47 AM by Hiort. 2 replies.
Page 1 of 1 (3 items)
  • 06-14-2011 5:45 AM
    Latest Firmware on BV10?
    My dealer tells me there is a later build than Build 165 (that I have installed).
    Does anyone know if there is a newer firmware, and what it´s supposed to fix?
    I have a problem with my BV10 that the dealer is hoping to cure by an FW update.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 06-14-2011 7:21 AM In reply to
    Re: Latest Firmware on BV10?
    Hello Hiort,
    my BV 10 was updated last month to build 166 by my dealer. I think this is still the actual build.
    But what is your problem you hope to fix with an update?
    /Räuber
  • 06-14-2011 9:47 AM In reply to
    Raeuber:
    Hello Hiort,
    /Räuber
    I described the problem in this post:
    http://forum.beoworld.org/forums/p/38623/320737.aspx#320737
    It has now appeared a few more times. I´m trying to have the TV replaced, but the dealer want to do the upgrade to be certain. I very much doubt that the update will do the trick. The latest time i had the "freeze" the volume numbers appeared on the screen slowly counted down, but no volume was changed.
    Very strange indeed.
    _____________
