Hi BeoWorlders,
I was wondering if anybody ever tried using BeoConnect with BeoPort only (= without a BeoMedia 1/BeoMaster 5): is it working at all?
My idea was to use the Mac with Itunes with the same BeoPlayer/BeoPort logic when it comes to Beo4 control, that means have the same coloured "favourites" playlists, ability to have the audio master sources on BeoPort via Beo4, among other things; coloured playlists are impossible with BMLink & Linkplayer.
Reunion Island is greeting you!
