Sibtain:
Hi Graham,
yeh tried that, it still doesn't seem to do the trick.
Maybe the BC1 just has something against Eric Clapton....Im using the DVD settings but i get a grey screen, then it just ejects
I'm no expert on the BC1 (which, incidentally, caused my first posting to the site when I couldn't get the radio to work!)
Has the BC1 been previously used in a set-up where a previous owner has optioned the Beo4 to take account of other B&O units in the same room (or has the BC1 been used as a 'slave' link to a different unit with a CD player?)
According to Lee in other postings the CD/DVD units are prone to developing faults, but if the DVDs play without problems then I can only imagine that this is a minor issue with the settings. Let us all know if you solve it!
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
