CAT7 is indeed more future proof. Due to cable quality, twisting and shielding, the quality of transmission is much higher, especially for larger distances. The most important difference is that CAT7 is rated for transmission of higher frequencies, hence better support for video; CAT5 is certified up to 100 Mhz, CAT6 up to 250 Mhz, CAT6a up to 500 Mhz and CAT7 up to 600 Mhz, CAT7a up to 1000 Mhz (thus supporting 862 Mhz. Cable Television directly without the use of transponders you need for CAT5/CAT6).
The same applies for the transmission speed, CAT6 is for up to 10 Gigabit connections (short distance :-), whilst CAT7 went up to 100 Gigabit for short distances.
However if distances are not that large and the quality of the cable is high, not to many bends, etc., you can expect decent till good quality on CAT5 as well. Just try it out I would say. I have tested high quality CAT5 cabling for TV signals distribution up to 25 meters and that was running smoothly.
