Both the BV8 and the Avant have ML (not sure if ML is standard fitted in BV8, no idea). So just a ML cable should do the job.Less distortion as the signal comes directly from the BV8 in stead of via the amplified and downforced MCL.
Its always possible to keep the 1611 for the BC9500.
