Latest post 07-22-2007 12:49 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 07-22-2007 7:41 AM
    • ben73
    • Not Ranked
    • Joined on 07-21-2007
    • Perth, Western Australia
    • Posts 22
    stylus
    my fairly newly aquired beocenter 7007 has a mmc5 stylus which i understand is pretty much the budget stylus for this unit (I think it is the orig stylus)...also vinyl just doesn't sound nearly as good as on my other B&O (beogram 1203 through a beomaster 901...which has its own problems thanks to poor packing by the ebay seller I bought it off)...is it worth investing in a soundsmith upgrade?  and how high should you go.  I do listen to a lot of vinyl so quality is important.  The prices do seem to increase exponentially tho.
    thanks
    Ben
  • 07-22-2007 12:49 PM In reply to
    Re: stylus
    The basic SMMC4 is extremely good. I would not bother going any further up the tree! It is quite a bit better than the original MMC4 .
