Seem to have a problem on board 8001032 board 3 in the service manual as the screen boots to indicate source but no volume ie as if muted - tried swapping to other unit same situation, thus, the problem is on here seems as if the amp board relay is not tripping - after a long day messing about, anybody any ideas, is the relay controlled by one of the bc547's or one of the surface mount jobs
help
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
