Latest post 07-18-2007 10:59 AM by Doc. 16 replies.
Page 1 of 1 (17 items)
  • 06-03-2007 11:48 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    BS3 panel new European BV7 (MK III) for both 40inch and 32inch ?
    Does anybody know if the BS3 panel for the new BV7 will be available for both the 40" and the 32"?
    On BeoWorld there is only talk about the 40"....
    Marcel
    Filed under: ,
  • 06-03-2007 12:03 PM In reply to
    Re: BS3 panel new BV7 (MK IV) for both 40" and 32" ?
    I understood it would only be in the new version of the 40"
    Regards Keith....
  • 06-03-2007 12:57 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    Keith Saunders:
    ...but let us hope the 32" version will get it too, may be later this year!!!
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 06-03-2007 1:34 PM In reply to
    • Doc
    • Posts 585
    Keith,
    Where / from who did you hear that?
    Marcel
  • 06-03-2007 1:55 PM In reply to
    I think the key question is still if the European BV7 will have an integrated BS3 like the US/Japanese BV7 will have or not. If it does then I doubt they do that for the 32" as well.
    Personally I and I am guessing here I'd think they will do a new chassis similiar to the BC6 for the Euro BV7 series (40 and 32). With the price point in Europe I can't see that they throw in a complete BS3, it is way too low to do that. If it is a new chassis rather then a full BS I don't see a reason why they would not do it for the 32 inch as well.
    Sad thing about it is, that I can't see them do a BV7 32 for the US which I am dying to have. That or a BC6.
    JK
  • 07-15-2007 3:15 PM In reply to
    • Doc
    • Posts 585
    Re: BS3 panel new European BV7 (MK III) for both 40inch and 32inch ?
    Any news?
  • 07-17-2007 1:07 PM In reply to
    User manual now on site.
  • 07-17-2007 2:38 PM In reply to
    • Doc
    • Posts 585
    Going to have a look right now!
    Big changes in it?
  • 07-17-2007 2:49 PM In reply to
    Interesting user manual....., Beo 5 is in it so it cant take long until it is relaesed!
    Just because it's mellow it doesn't mean it's less evil....
  • 07-17-2007 3:29 PM In reply to
    • Doc
    • Posts 585
    YES!
    Noticed it also.
  • 07-17-2007 3:35 PM In reply to
    • Doc
    • Posts 585
    Are there any changes on the DVD-player? The manuel doesn't mention blue-ray...........Sad
  • 07-17-2007 3:42 PM In reply to
    • Alex
    • Bath & Cardiff, UK
    • Posts 2,990
    They won't change the drive until they can be 100% sure which format is going to win.
     Weekly top artists:
  • 07-17-2007 3:45 PM In reply to
    • Doc
    • Posts 585
    A bit of a shame, I think.
    But, I have a PS3 I can connect, can't I ? But it can't be operated by the Beo5 because it needs BlueTooth-signal, or am I wrong?
  • 07-18-2007 2:29 AM In reply to
    As far as I know your dealer has to program the Beo 5. I don't know if it works with Blue Tooth. Maybe some of the members who were in Struer and actually held it in their hands (envy, envy) can comment?
  • 07-18-2007 4:18 AM In reply to
    • Doc
    • Posts 585
    Also thought I have read an older thread about connecting a PS3 (but have to search where)
  • 07-18-2007 4:58 AM In reply to
    • Alex
    • Posts 2,990
    There was a way of doing it, as the Beo5 has no bluetooth, same as all other remotes. However, the solution was pretty clumsy and involved the signals travelling through a PC, which had a bluetooth adapter and IR receiver connected.
     Weekly top artists:
  • 07-18-2007 10:59 AM In reply to
    • Doc
    • Posts 585
    Yes, found the thread.
    Ain't going to try that.
