Hi, the French company Madsystemes makes an adaptor that allows you to use the 3500 as a true Powerlink speaker, so basically with a 5-pin DIN connector, you should be able to connect it to a preamp, the question being to know how to turn on & off the BeoLab..
Reunion Island is greeting you!
