So I've done this before but I've completely forgotten how to do it!
Basically, I bought a used Beocenter 2300 and Beo4 that were being used with a MX7000 TV. I don't have a TV and the remote still thinks there is a TV, so the BC2300 won't respond.
I've reset the remote and that hasn't worked - I remember there is some option that needs setting when you use it with a TV. If anybody could jog my memory that would be much appreciated!
Cheers, Jon
