s i took out my cartridge and put it back. before that everything worked fine but after that i have no sound at all.
i can get sound if i connect an external device like my dvd player or set top box, but don't get much volume. it doesnt matter
if the volume control is at max or zero, it is exactly the same. so i can only get reasonable volume when the external device
is turned up to max. so i think my beocenter is acting purely as a conduit to connect my dvd or set top box to the speakers
and relying on the receiver of the external device for sound. does this mean my receiver has gone or is it more likely an electronic
or connection issue? how can i work this out?
