Latest post 04-05-2011 4:16 AM by jahur. 12 replies.
Page 1 of 1 (13 items)
  • 04-04-2011 9:57 AM
    • jahur
    • Top 500 Contributor
    • Joined on 02-07-2011
    • planet zonk
    • Posts 161
    heavyweight vinyl beware!
    just thougt id best mention that heavyweight 7" singles and the beogram 9500 hold no favour for each other.
     the beogram 9500 has trouble with automatically detecting the weight of this type of vinyl. the beogram thinks its 12" or an album and decides to set itself on the edge of the platter, needless to say i was in all of a panic seeing as its an original cartridge.
    im going on the assumption that the beogram 9500 goes by weight in order to detect the relevant vinyl size. my other 7" singles have no problem except my two box sets of morrissey's singles. my original versions work perfectly. the newest re-releases are pressed heavy weight versions.
    hope this makes sense.
    (formerly nokinnikon from the old site)
  • 04-04-2011 11:45 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: heavyweight vinyl beware!
    jahur:
    Not quite.  An LP will depress the center disk on the platter; a 45 won't.  That's how it determines size.
  • 04-04-2011 11:50 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    how strange.....the my other lighter older 45's work perfectly, its this new batch of 7" 45's wont trigger the feature. the 7" lifts up slightly then resets down for the vinyl. but doesnt lift the new batch of 7" heavyweight vinyls. does this make more sense?
  • 04-04-2011 11:56 AM In reply to
    mediabobny:
    Not quite Wink
    A large-hole single will depress the center hub, but not all the way. This is the LP/45 difference, as you say. Put a regular single on it and press start - notice the record will lift a bit and come back down before the arm reaches it... and this is how the deck decides between the different 45 sizes, the bigger ones won't rise. It may well be confused with a heavy, small size record.
    -mika
  • 04-04-2011 11:59 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    aha, so i wasnt far off.... just got a fright when i heard a grating sound.....
  • 04-04-2011 12:19 PM In reply to
    The Beogram of this type is solely sensing sizes by weight depressing the center hub. Heavyweight 7" singles can be over the loading "limit" for LP's which can be as light as under 90 grams Smile
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 04-04-2011 12:25 PM In reply to
    • jahur
    • planet zonk
    • Posts 161
    so i was right, it does sense it by weight! i thought it did, how else would it know the difference??? weight sensing would be more cost effective and less of a headache to shoehorn into such a small area, i guess
    anyhow those who have the beogram9500 or the like beware of heavyweight seven inch 45's! you may end up losing the tip of your needle!
  • 04-04-2011 1:04 PM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Yes you will need to treat these like you would 10" records, i.e. cue manually! It was a huge letdown for B&O to omit the optical sensor in these decks especially considering the fact the deck was desgned to be operated from anywhere within the linksystem!
    Just imagine you had played an album the previous night, then another family member wacked a new 10" single on the deck without you knowing. You later continue playing your album from your study only to be greeted by a scraping noise as your mmc1 carves new tracks into the platter Surprise
    Olly.
  • 04-04-2011 1:42 PM In reply to
    • jahur
    • planet zonk
    • Posts 161
    omg! im not alone then! very good point you made there with regards to the sensor and link system.
    thought i was going mad...
  • 04-04-2011 4:44 PM In reply to
    Even more frightening is when the detector system for a 4000 does not work! However B&O had thought of this and the cantilever wrecking ribs have a cut out at the correct place. the arm drops but the tip of the stylus is a tiny bit higher than the dip in the rib! Still slightly unnerving though!
  • 04-04-2011 5:01 PM In reply to
    • jahur
    • planet zonk
    • Posts 161
    god yes, each revolution of the platter with the needle grating is one step closer to soundsmiths with a wad of money! not the stuff dreams are made of!!!!
    are the needles (original mmc/etc) very hardy or very susceptible to damage?
  • 04-05-2011 4:14 AM In reply to
    They are pretty hardy, partly because they track at a very low weight. Using them to play metal platters is, however, not recommended! Big Smile
  • 04-05-2011 4:16 AM In reply to
    • jahur
    • planet zonk
    • Posts 161
    ha ha ha spot on!
