If you saw my Beovox M70 thread in Vintage you know I made a "bread board" to try different parts in the crossover network. Now that the M70s are restored, I cleaned up my work space and cleaned out the "Bitz Box." Pictured below are several slightly used capacitors purchased last fall for the crossover network experiment. I doubt I will ever use these, so I'm offering any or all free to a good home.
All have less than an hour or two of music on them. As stated above, all were purchased last fall. All were purchased from Mark at Meniscus. All are rated at 100 V. More details:
Two ERSE 8.2 uF (+/- 10%)
Two (no manufacturer on part) 12 uF (no tolerance on part)
Three ERSE 15 uF (+/- 5%)
Two BENNIC 22 uF (+/- 10%)
One ERSE 33 uF (+/- 5%)
Two ERSE 47 uF (+/- 5%)
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
