Latest post 03-28-2011 3:03 AM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 03-27-2011 3:38 PM
    Do RL60.2 speakers fit on wall mounts from RL45 speakers?
    Does anyone know if RL60.2 speakers will fit on the original wall mounts that were delivered together with RL45 speakers?
  • 03-27-2011 3:53 PM In reply to
    Re: Do RL60.2 speakers fit on wall mounts from RL45 speakers?
    The terminal hole in RL 60 is 60 Mm square, if RL 40 is the same, they fit
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-27-2011 4:19 PM In reply to
    Thanks Søren. It would be nive if anyone can measure the hole in a RL45 speaker. the speakers are at my parents. So I am not able to measure it. And when I ask them to do so I do not trust the answer Smile
  • 03-27-2011 5:07 PM In reply to
    pacificocean:
    What your father says is always correctBig Smile
  • 03-28-2011 3:03 AM In reply to
    Yes, they fit. The mounts are identical.
    RL45, RL60, RL2000 and RL6000 all have the same mounting brackets.
    RL140 and RL7000 brackets are considerably bigger.
    Regards Graham
