Confused,  Alex says "Don't use a pair (of Beolab 4000's) - they'll only couple and give you more volume at lower
 frequencies. They'll actually sound quite unpleasant at higher
frequencies as you move off-axis. Stick to one speaker".
http://forum.beoworld.org/forums/p/32126/260686.aspx#260686
Others say use a pair!
Which method is right please?
It would be more convenient to use just one but finding it difficult to see the difference.
