Latest post 03-09-2011 5:05 PM by ph111p. 2 replies.
Page 1 of 1 (3 items)
  • 03-09-2011 4:55 AM
    • ph111p
    • Not Ranked
    • Joined on 03-09-2011
    • Posts 4
    Beovision 6 in link room and sky drx switching off and on every 10 seconds
      Hi can someone please help i have a recently upgraded my sky box from an old sky plus box which worked fine in the link room with beo 8 32 as a master and the beo 6 22.
       I have now upgraded with the latest 2011 sky hd box in the link everything works fine if i leave the master on but when master is off and i try to watch sky in the link room the sky box keeps turning off and on on its own can someone please help any ideas appreciated.
      I have changed the scart control too (off) in the sky but still have the problem should i change the t.v settings on the link as it seems the link is turning the sky box off and on automatically.
  • 03-09-2011 11:20 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beovision 6 in link room and sky drx switching off and on every 10 seconds
    Check the settings menu of your Sky box and look to see if "scart control" is switched on.
    Opman
  • 03-09-2011 5:05 PM In reply to
    • ph111p
    • Not Ranked
    • Posts 4
       Hi scart control was off i have now changed the settings hopefully it will sort it thanks.
