Latest post 03-19-2011 3:36 AM by Peter. 7 replies.
Page 1 of 1 (8 items)
  • 03-18-2011 11:31 AM
    Beomaster 6500 and Beolab 4000s
    Gentlemen,
    I just hooked up my Beolab 4000's to my Beomaster 6500. At first I tried running one Powerlink Cable to the first Speaker and then out of Speaker 2 running a Beolink cable to the second speaker. I had almost no volume. I then hooked them up the normal way, one speaker to one powerlink and it works just fine. But it leaves me with a problem, how do you put a powered sub with the 6500? The 4000 lack bass for my room and I really need a sub. Any suggestions or thoughts?
  • 03-18-2011 11:40 AM In reply to
    Re: Beomaster 6500 and Beolab 4000s
    It should work when daisy chained - did you have the selctor switch set with one to left and the other right? Powerlink cables carry signal for both left and right and there should be no problem daisy chaining as you describe. If using a B&O subwoofer, the best way is to connect the subwoofer to the Beomaster and the 4000s to the subwoofer as the subwoofer will remove the lowest frequencies which will help the performance of the 4000s.
  • 03-18-2011 11:53 AM In reply to
    Peter,
    Yes I had one set to left and the other right but with what you are telling me to come out of the 4000's to the sub takes care of the problem. Or at least it should.
    Thank you!
  • 03-18-2011 12:09 PM In reply to
    Well Ok so much for simple solutions. If I use the Speaker 2 out of the 4000 the volume again goes to almost nothing. The minute I unplug the sub volume is restored. I tried going from Speaker 1 to the sub with the same results. Strange isn't it? It is almost as if the Speaker 2 output defeats the volume control.
  • 03-18-2011 12:28 PM In reply to
    Have you tried both speakers? I wonder if one has a fault.
  • 03-18-2011 12:45 PM In reply to
    Well just tried the second speaker and the same result. I have tired it with B & O cable and also with custom cables made by Kelly Smith here in the USA. He makes some very good cables but I wanted to make sure that wasn't the issue. I have a second set of 4000s I think I will try them and go from there.
  • 03-18-2011 7:56 PM In reply to
    What Peter sugested was go from BM to subwoofer, from subwoofer to BLs, as I understand your explanation you did not try that.
    Only my comment, as I read and understand the thread.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-19-2011 3:36 AM In reply to
    If the second speakers do the same, I would suggest the cables are not correct.
