A work colleague's father sadly passed away recently and he has the
following items available:
The main item is the Beosystem 5000 (Beogram 5005, Beomaster 5000, Beocord
5000, Beogram CD 50 and a Master Control Panel 5000) all of which is believed
to be in perfect working order.
The pictures below show you everything in detail.
The TV (as I understand works, but is a little temperemental so is for
spares / repair).
The items can be picked up from Hazlemere GU27 or Send GU23 in Surrey, or my
colleague will deliver locally if needed. Any reasonable offer will be
accepted.
Please email me at danielezro@hotmail.com if you are interested.
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
  Normal
  0
  false
  false
  false
  false
  EN-GB
  X-NONE
  X-NONE
 /* Style Definitions */
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-style-noshow:yes;
	mso-style-priority:99;
	mso-style-parent:"";
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin-top:0cm;
	mso-para-margin-right:0cm;
	mso-para-margin-bottom:10.0pt;
	mso-para-margin-left:0cm;
	line-height:115%;
	mso-pagination:widow-orphan;
	font-size:11.0pt;
	font-family:"Calibri","sans-serif";
	mso-ascii-font-family:Calibri;
	mso-ascii-theme-font:minor-latin;
	mso-hansi-font-family:Calibri;
	mso-hansi-theme-font:minor-latin;
	mso-bidi-font-family:"Times New Roman";
	mso-bidi-theme-font:minor-bidi;
	mso-fareast-language:EN-US;}
