Latest post 07-15-2007 1:59 PM by Peter. 5 replies.
Page 1 of 1 (6 items)
  • 07-15-2007 7:50 AM
    beomaster 6500 hums
    Hello to everybody,
    I am a proud owner of a beosystem 6500.
    Unfortunately the beomaster started to hum. It comes from the right back of the enclosure. I suppose it is the power supply, but I am not sure.
    It is not that loud, but especially in the evening at time it is quite outside a can hear that noise in the whole living-room.
    There is no difference, if the master is turned on or off,or if anything is connected. (also if every wire is disconnected.)
    The system is working fine,no other things I complain.
    Does anyone know, what it might be and how I can solve this problem?
  • 07-15-2007 9:29 AM In reply to
    Re: beomaster 6500 hums
    It will be the transformer. The original option would be to replace the transformer but these will not be easy to source. Check it is seated properly in the case. If you are able to decouple the BM from its surroundings, this can help. I use a couple of rubber supports underneath my BM4400 which hums. The noise is amplified by the wooden cabinet and the rubber seems to prevent this. Some people use squash balls cut in half under each corner.
  • 07-15-2007 11:16 AM In reply to
    Thank you for your fast reply; I did as you told me.
    I used some thick felt and attached it below the BM's feet. Also, there is no more other syste component standing on the BM.
    But the result is not really satisfying.
    How can I reseat the transformer in the BM? I suppose to get the service manual in order to open the enclosure. (difficult)
    And then?
  • 07-15-2007 12:17 PM In reply to
    The manual is actually on site. I think all the Beomasters in this range use the same transformer so an otherwise non operative model could be your answer.
  • 07-15-2007 12:47 PM In reply to
    I have downloaded the service manual. Is there anything to consider when I reseat the transformer?
    2) Would you mind to upload the following missing service manuals:
    BeoGram CD 6500
    BeoCord 6500
    Thank you!
  • 07-15-2007 1:59 PM In reply to
    I don't have every manual! Unfortunately I have to beg borrow or steal what I can! I am working on the CD one!
