Latest post 02-09-2011 5:06 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 02-08-2011 7:42 PM
    Beogram 4004 Remote Start/Stop Question
    I like the Beogram 4004's looks much better than those of the Beogram 8000. Hence I am wondering, is the start/stop remote control function of the Beogram 4004 downward compatible with the datalink interface of the Beomaster 8000 (or in other words, would the 4004 start playing when pressing Phono/ stop playing when selecting a different source on the 8000)? Did anyone try this? Thanks!
    Rudy
    Filed under:
  • 02-08-2011 7:50 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beogram 4004 Remote Start/Stop Question
    Looking at the BG4004 page on Beocentral, I would say no. It appears to use a different datalink system.
    CraigSmile
  • 02-09-2011 3:59 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Craig is correct, the remote system in the 4004 is much simpler and not compatible.
    Olly.
  • 02-09-2011 5:06 AM In reply to
    The remote function of the BG4004 will only function with Beomaster 2400-2
    Regards Graham
