Latest post 02-05-2011 4:24 AM by joeyboygolf. 1 replies.
Page 1 of 1 (2 items)
  • 02-04-2011 3:11 PM
    • bajan
    • Not Ranked
    • Joined on 02-04-2011
    • Posts 1
    Beocentre 9000
    Hi...I recently purchased a mint Beocenter 9000 system and would like to add a Beogram to it.  Can anyone suggest what model of turntable to go with...
    I appreciate any info.
    Steve
  • 02-05-2011 4:24 AM In reply to
    Re: Beocentre 9000
    Any B&O turntable will work with the Beocenter 9000 either through the PHONO socket or the AUX socket depending on which turntable you buy!
    I suggest that this article would make suitable reading, before you make a decision.
    http://www.beoworld.org/article_view.asp?id=67
    Regards Graham
