Latest post 03-10-2011 2:56 PM by Søren Mexico. 5 replies.
Page 1 of 1 (6 items)
  • 03-09-2011 7:07 PM
    connecting speakers to a beomaster 1900
    I just picked up a beomaster 1900 and beogram 3400 from a friend. i've got the two connected but am at a loss as to how to connect speakers to the beomaster 1900. any ideas? i've never seen speaker ports like this before.
  • 03-10-2011 1:20 AM In reply to
    Re: connecting speakers to a beomaster 1900
    You will need a couple of 2 pin DIN loudspeaker plugs.
    Regards Graham
  • 03-10-2011 5:04 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    type speaker din into ebay there are plenty of options including pre-wired or screw terminal etc.
    Olly.
  • 03-10-2011 8:52 AM In reply to
    If in US here last item on page
    Image here
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 03-10-2011 12:30 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Both screw-mount and solder types are available.
    Check Ebay (or ask me).
    Impressive how many people never saw DIN speaker sockets before.
    It's the only worldwide standardized socket/plug type for home audio speakers for 50 years.
    Everything else is non-standard, proprietary or homemade.
  • 03-10-2011 2:56 PM In reply to
    Its amazing to see, specially in new equipment, how bad connecters they have, screw naked cable directly, banana, cheap RCA, good plugs like the DIN line is only for computers, and after selling you an expensive reciever/amp with crap connections, they want you to buy "audiophile" cables for the same price as the reciever/amp
    And on Ebay US they charge up to 10.00 US for one 2 pin DIN, description: special B&O vintage speaker plug, they also sell some cheap China made screw mount where the screws pops out the first time you connect a cable to them.
