Latest post 02-11-2011 12:27 PM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 02-09-2011 6:30 PM
    ir codes for velodyne
    After months of auditioning subwoofers i opted for a velodyne 1200 ultra which came with a little remote control.
    Strange b&o have not made a quality sub yet????
    My question is can a beo 5,6 control this. the velodyne website has ir codes, can these be loaded in to the remote.
    regards sparks
  • 02-11-2011 12:27 PM In reply to
    Re: ir codes for velodyne
    Sparks,
    The Beo5/6 CAN control this product.
    I looked on their web site and they provide HEX pronto codes which can be converted.
    These codes convert to NEC 32 bit protocol.
    I have converted the codes defined as "SPL Ultra Series" and produced an XML file for you to test.
    You can download it HERE
    Regards Keith....
