Latest post 01-17-2011 3:27 PM by chuggsymalone. 4 replies.
Page 1 of 1 (5 items)
  • 01-16-2011 4:19 PM
    Beovox S55 broken
    Hello
    I have just inherited a wonderful Beosystem 5000 complete with Beovox S55 speakers. However the foam on the woofers has perished. Does anyone know whether (and how) to repair or replace them?
    Richard
  • 01-16-2011 4:32 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beovox S55 broken
    Hi Richard, and welcome to Beoworld. What you have is a very common condition known as foam rot. You will need a repair kit like this.
    Beovox S55's foam rings & glue
    You will find plenty of threds on here showing you how to fix them. Also worth changing the caps in the crossover too. One of our members (Dillen). can supply these.
    CraigSmile
  • 01-17-2011 6:22 AM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Definitely worth repairing. I had mine refoamed, didn't feel I was up to the job of doing it myself. Replaced the capacitors on the crossovers as well. Like new again!
    Durban South Africa
  • 01-17-2011 3:25 PM In reply to
    Thanks Craig for your speedy advice. I have ordered the foam rings already - I will see if Dillen posts anything!
  • 01-17-2011 3:27 PM In reply to
    Good advice, BenSA - I am not sure if I am prepared to take the risk of fixing them myself either! I guess it is a job worth doing properly or not at all. I will look into replacing some components too.
