DoubleU: The DVB-S module will soon be obsolete. More and more stations in the Netherlands are making the switch to broadcast their programs in mpeg4 (not HD). I guess Austria won't be different. Module 4042 is not capable to decode mpeg4 signals. You will need the DVB-HD module to watch these stations. Alternative is an external STB. A lot cheaper then +500 EURO!
Wow, thanks a lot for this information. Did not know about a change in the technique of DVB-S broadcasting. Would be a big change like the one from analogue TV to DVB-T.
DoubleU: An ATV2 only uses hdmi-out for sound and picture and an optical output for sound. So unless there is an (optional) Dolby Digital decoder in the BV6 you can't use the ATV2. And you still need a device to convert from optical > coaxial. An external DAC is your alternative.
not sure I understood correctly. If I use a DAC it should work with DVI for Video and analog Audio in for Audio. Correct? Just without a DAC I ywould need the DSS module for digital COAX Audio in?
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
