Latest post 01-18-2011 2:50 AM by chartz. 1 replies.
Page 1 of 1 (2 items)
  • 01-17-2011 7:33 AM
    Beocord 9000 speed problem
    Hello, I have a small problem with a newly restorated Beocord 9000.
    when playing or recording, the speed seem constant in the beginning, but flutter and "tape wobble" is clearly being stronger when more tape comes to the take-up reel. It can only be heard on semi-long notes, like a piano, organ and guitar solos. Help please...
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 01-18-2011 2:50 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Re: Beocord 9000 speed problem
    The obvious ones are:
    -the capstan belt,
    -the capstan pinch roller itself may be glazed,
    -the motor (listen to its noise, it shouldn't produce any grinding noise).
    Other than that, I join an email from Tim Jarman about the same problem I had on a BC 8000 (same transport):
    Tim Jarman:
    Check the brakes, there are three felt pads that act on the spool
    carriers (best accessed with the cassette tray removed), they can get
    gummed up with dirt and cause this sort of thing. After repair work they
    can also get re-fitted wrongly, check this too. I assume that your
    mechanical overhaul has included removing the spool carriers from their
    shafts, cleaning away the horrible old grease and lightly re-lubricating
    them? This is very important in all Beocords as stiffness here can cause
    needless head wear.
    For me, a new pinch roller and cleaning the brakes did it.
    Jacques
