I have a BV10 and attached to it is a Panasonic Blu-Ray 500GB HDD. The model is DMR-BW880GLK. The model loaded on the tv puc control is Panasonic DMRBS850. The dealer advised this is similar and should work.
When using a Beo4 everything works perfectly and I'm able to control most things. The Beo5 has been loaded with the control profile of the DMR BS850 (so I'm told). The operation via the Beo5 is a dogs breakfast with most of the screen buttons not working or doing totally unrelated functions.
Is there a way to reconfigure the buttons so the Beo5 actually does the correct function. The Beo4 works well so I assume the Beo5 should do the same.
I must say the Beo5 is the most frustrating B&O product I have bought. It all seems so hard to get it to work properly. It should have been a great product and I think B&O were not totally sure what they wanted it to do and how they want to implement it.
Thanks for any suggestions.
Peter
