Latest post 07-17-2007 12:59 PM by Doc. 3 replies.
Page 1 of 1 (4 items)
  • 07-15-2007 3:21 PM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Difference between panel and chassis
    Can anybody tell me what's the difference between the panel and the chassis of a (BV7) TV?
    Marcel
  • 07-17-2007 10:37 AM In reply to
    Re: Difference between panel and chassis
    Marcel,
    In its most simplist form a panel refers to the LCD panel in the BeoVision 7 which is made by a third party company. The chassis is the electronics which drives the panel and everything else. B&O do not make their own LCD panels.
    Regards Keith....
  • 07-17-2007 12:06 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Think of the panel as the 'canvas' on which the image is displayed, it's the bit you see.
     Weekly top artists:
  • 07-17-2007 12:59 PM In reply to
    • Doc
    • Posts 585
    Oke, get the idea.
