Latest post 01-01-2011 12:38 PM by Doctor. 1 replies.
Page 1 of 1 (2 items)
  • 01-01-2011 11:59 AM
    • TT4me
    • Not Ranked
    • Joined on 01-01-2011
    • Posts 2
    How do I reinstall the dust cover on my RX?
    I took it off to clean it up and get out some scratches.  Does anyone have a good technique for reinstalling it?  Seems like I might need to grow at least two more hands.
  • 01-01-2011 12:38 PM In reply to
    Re: How do I reinstall the dust cover on my RX?
    Did you remove the spring? In that case you need three hands! Smile Seriously though, it is just patience and making sure none of the plastic parts break. The spring is just a torsion bar which is held be three screw down plates. The RX also has two metal pins which slide out if I remember correctly.
