Latest post 04-26-2011 2:51 PM by Spiros. 3 replies.
Page 1 of 1 (4 items)
  • 04-18-2011 7:09 PM
    • dug11
    • Not Ranked
    • Joined on 03-10-2010
    • Posts 50
    • Silver Member
    Best Amplifier to Beovox Penta
    HI ALL
    im happy owner of Beovox Penta speakers and i looking to buy amp different that my beomaster 5000
    i am looking for beomaster 4500 is this is good idea?
    or any other wich can be wall mounted.
    thanks
  • 04-18-2011 7:45 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Best Amplifier to Beovox Penta
    I think the 4500 might be a step down in terms of performance.
    If you are trying to tidy up the look, source some amps (beolab 150 or 200 or maybe even one of those MCL2_ units) for those Pentas. I bet they play better with more power. Or get some 3rd party stand alone amp (onkyo, marantz, nakamichi, Niles... Etc) that has a DC trigger and use the powerlink to control that from the new 4500. Steve @ sounds heavenly made my cable.
    I feel like I should have used PowerPoint for this post! Laughing
    Evan
  • 04-26-2011 2:46 PM In reply to
    • dug11
    • Not Ranked
    • Posts 50
    • Silver Member
    what about beosound overture? is there any way to plug passive speakers to it?
    its maybe a silly question but i don`t know....
  • 04-26-2011 2:51 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    You will a beolink passive or the older version, the MCL2P.
    These are usually being used for link rooms but they can also be used as amps. I use 3 in different rooms and in 2 of them are connected on Overtures
    Best regards
    Spiros
