Latest post 12-13-2010 4:15 AM by Dillen. 9 replies.
Page 1 of 1 (10 items)
  • 11-01-2010 3:48 PM
    • Scapino1
    • Not Ranked
    • Joined on 02-01-2009
    • Rotterdam, the Netherlands
    • Posts 10
    Beocenter 3300 - low frequency noise from the speakers
    Hi All,
    Recently when I've finally bought the working well pick-up the new problem arose. Since some time the buttons couldn't be pushed - literally they may have been pushed but they didn't stay in the  position, so the beocenter couldn't be turned on. Actually after continuously pushing the buttons (let say after 30 pushes) it may have been turned on. I guess it is not normal. And recently with the same procedures - the low frequency noise appears from the speakers after turning on the beocenter. And more recently it can't be even turned on.
    Thanks in advance for help.
  • 11-01-2010 6:12 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 3300 - low frequency noise from the speakers
    Beocenter 3300 is one of the classic Jensen designs, great sounding amplifier and
    a pretty good tuner too. Worth restoring and using.
    The pushbutton problem will be dust in the power switch.
    Dismounting and taking the switch apart is a fiddly job but it can be done
    and the contacts inside can be cleaned while in there.
    Watch out for stray springs and contact leaves when you open the switch.
    I did this to a Beomaster 2200 just yesterday (same machine only without the record player).
    The other problem is most likely the power supply module in need
    of new capacitors, that's very common. It could also be an amplifier issue, too high idle currents
    and/or bad capacitors. A capacitor kit exists that covers the whole Beocenter.
  • 11-01-2010 6:42 PM In reply to
    As Martin says, the pushing contact mechanism may need cleaning, and
    A capacitor problem may cause the unwanted hum. Great machine when working, though :)
    -Søren
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 11-02-2010 4:36 PM In reply to
    • Scapino1
    • Not Ranked
    • Posts 10
    Thank you guys for all these comments. Just two more questions.
    Is there any manual how to disassembly the beocenter? The amount of screws and complexity of construction resembles a kind of puzzle where unscrewing not a right bolt will result in selfdestruction:).
    Where I can get this cap kit? What does it consist of? Does it cover all  mentioned problems with caps? Can I get somewhere any diagram to get to know which cap is for what?
  • 11-02-2010 5:36 PM In reply to
    • Dillen
    • Posts 5,008
    The service manual is available for download from our main website for silver and
    gold members (well worth the small membership fee).
    Actually we don't have the Beocenter 3300 manual so you will choose the manual
    for Beomaster 2200 since this is the same machine as your Beocenter 3300, only without
    the turntable so will be close enough.
    I can supply the cap kit and it contains new components for all board-mounted
    electrolytic capacitors (read: those that normally fail).
    Remove the black metal bar at the rear (losen a couple of screws at the rear edge
    near the top).
    Remove the large aluminum cover (a couple of screws and one or two plastic holders).
    Remove the hinged aluminum lid together with the black metal mounting bracket
    that goes across the cooling fins etc. Note that there is a spring for the hinged lid
    that needs to be taken care of as you lift off the assembly.
    This model is a modular build so not too difficult to work on if you are just a bit tech skilled.
    The service manual will tell you all.
  • 11-27-2010 12:56 PM In reply to
    • Scapino1
    • Not Ranked
    • Posts 10
    All the comments were helpful. I disassembled all the buttons and cleaned them - that works fine now.
    I exchanged also 3 electrolytic capacitors - the ones with the traces of leakage - C3,C4,C7 at section 5 (according Beomaster 2200 manual).
    Unfortunately the other problem occurs now. When I turn the beocenter on, the single sound appears and nothing more - no sound at all. Moving up or down the volume slider has no effect. The illumination of the frequencies indicators works and the capacitors in section 5 are warm also. I noticed that one from 1AT fuses is missing also. However it has never been there and the beocenter used to work. Any hints what might be the problem now?
    Jacek
  • 11-28-2010 2:48 AM In reply to
    • Dillen
    • Posts 5,008
    Good job with those buttons !
    I suggest you replace the rest of the capacitors in the kit too.
    The ones in the power supply section are particularly prone to failure.
    You cannot tell if they are bad by looking at them, some will leak - they are easy to spot
    but others will dry out and you can't see that.
    It's typical for the Beomaster 2200 and derivate Beocenters 3300 and 4000 to mute
    when the power supply is unstabile.
  • 12-10-2010 2:00 PM In reply to
    • Scapino1
    • Not Ranked
    • Posts 10
    Finally had time to make some progress with a repair.  I've exchanged all the electrolyctic capacitors in the power supply module. Unfortunately the problem still exists. I also spotted that PCB under the Zener Diode D6 in power supply looks like burned - the surface is black. Do you have any idea what might that mean?
    I will continue with exchanging the capacitors in the amp sections and it will hopefully help.
  • 12-12-2010 3:11 PM In reply to
    • Scapino1
    • Not Ranked
    • Posts 10
    The real problem was actually a muting switch in the buttons' section - placed near P3 button. When I cleaned them before I adjusted a torsional spring and the muting switch was continuously closed. Now everything works - I checked with the muting switch forced to be open. However I have to adjust again this small torsional spring and this is a tedious job and I simply cannot get it right in the way that it mutes a signal while switching the programs. I couldn't also push any button that it stays in its pushed position, but I think it may be also solved by adjusting the relative position between the plastic sliders and the muting switch.
  • 12-13-2010 4:15 AM In reply to
    • Dillen
    • Posts 5,008
    Nice job !
    The problem with non-latching pushbuttons is usually because the power switch
    doesn't release completely. This, in turn, does not release the locking rod inside the switch assy.
    If this is the case, you may have to take apart the power switch (THAT is tedious), clean everything
    and put it back together.
    A spring with a little higher tension for the power switch can sometimes also solve it.
