Latest post 07-12-2007 5:21 AM by Coolskin. 8 replies.
Page 1 of 1 (9 items)
  • 07-11-2007 10:33 AM
    ATAPE
    Hello everybody,
    I have an avant masterlinked to a BS9000 and everytime I push the beo4 "ATAPE" key, all the system turns on (BV+BS), but logically nothing happens because I've not any "audio tape" connected (in fact I have no idea of which audio input is really active in this case);
    so the question is: can I "turn off" this command in the system (to keep it off) in order to use this "unused" beo4 key for another purpose?
    Thanks in advance.
    Santiago
  • 07-11-2007 10:43 AM In reply to
    Re: ATAPE
    A-TAPE will activate the Aux input on your BS9000, which is why it all turns on.
  • 07-11-2007 11:13 AM In reply to
    Re: ATAPE
    meandmyshadow:
    Thanks!
    I presume that a B&O audio tape plugged there, can be fully controlled by using the ATAPE (or AMEM) beo4 key; but with any other audio device connected, the "A.AUX" beo4 command will do the same work.
    So I'm afraid this means there is no way to "switch off" this feature in the system Sad (via setup, menus...),  isn't it?
    Santiago
  • 07-11-2007 11:46 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: ATAPE
    Santiago:
    meandmyshadow:
    Thanks!
    I presume that a B&O audio tape plugged there, can be fully controlled by using the ATAPE beo4 key...
    The AUX port on the BS9000 is not equippet with Datalink, hence you will not be able to control a tape recorder. All (I know of) Beocords are remote controlled through a Beomaster via Datalink.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 07-11-2007 12:29 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Re: ATAPE
    My A-Tape activates my SD Card in my Beosound 4.
    Useless info but interesting nether-less . Cool
  • 07-11-2007 12:49 PM In reply to
    • UK
    • Posts 970
    Re: ATAPE
    I hope to win a new Beo4 with AMEM instead of ATAPE in this months prize draw
  • 07-11-2007 12:59 PM In reply to
    Re: ATAPE
    I think it still sends the same code, it's only the writing on the button that changes!!
    Regards Graham
  • 07-11-2007 1:17 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: ATAPE
    joeyboygolf:
    Graham you are correct, the Code is still the same.
    CraigBig Smile
  • 07-12-2007 5:21 AM In reply to
    Re: ATAPE
    Craig:
    joeyboygolf:
    CraigBig Smile
    "The names are changed to protect the innocent"
