1st March February 2012
Latest post 12-09-2010 6:49 PM by Vienna. 16 replies.
12-04-2010 6:33 AM
vikinger
- Joined on 04-16-2008
- Vestri Kirkjubyr, UK
- Posts 2,839
Getting a better understanding of B&O capabilities
Where is the best place/ best manual to get a good overall understanding of B&O's capabilities? I ask this as I sit within listening distance of a stand alone BC1 which is just out of sound-synch with the BV5 on the same channel elsewhere in the house.
How do I link the TV's to get perfect sound synch? How do I watch a DVD playing on the BC1 on the BV5? I know it's all possible, but is it straight forward? I have the relevant link modules in my TVs and can read the manuals, but I have a feeling that there are a lot of us between the technology guys at one extreme, and the expensive dealerships who will wire/cable your house at the other, who for want of a little guidance or effort just don't quite get the best out of our B&O equipment.
And what about all those Beolink modules and converter units? How do I choose and do I need any?
(Time to turn the TV's off and switch on the NRadio (Pinnacle) and non-networkable 40 year old BM2000)
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
vikinger
- Posts 2,839
Re: Getting a better understanding of B&O capabilities
vikinger:
Graham
Hmmmm.
Back to the manuals then.
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
vikinger:
Hmmmm.
Or pop into your friendly local Bang & Olufsen dealer for a nice relaxing coffee and a chat about what you want from your system
Maybe have a listen to BeoSound8 whilst there.
vikinger
- Posts 2,839
I have found the B&O Configuration manual on the main site. There are two downloads available: one is an .exe file and the other a .zip. Unfortunately the zip seems to be an exe in disguise and I cannot get any mac application to open it. (Would not be a major problem except that my faulty Windows Toshiba now has a usable screen about 30mm in depth!)
(I'm sure I've encountered something similar in the past with Windows pdfs that turned out to be pdfs that only a windows OS could open: bit pointless producing modified universal file formats that don't work on other platforms. )
Can anyone at Beoworld check the zip file on the main site or convert it into a pdf?
Graham
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
It's a Windows program, not a document - so not directly useful to you, unless you have a Windows emulator on your Mac.
vikinger
- Posts 2,839
tournedos:
Thanks Mika. Should it be called something else then? (Not a document or manual?)
Graham
EDIT. Does that mean that the zip file is not a zip file?????? It's a zipped exe file??????
tournedos
- Finland
- Posts 5,808
Yes, it is a zip file, which contains an .exe file
I
believe this weirdness is because at some point, the content management
system on site didn't directly allow delivering executables. All it's
made for is delivering documents.
david coyne
- Joined on 04-17-2007
- Sydney, Australia
- Posts 165
vikinger:
Graham
Hello
Interestingly I have a similar sync problem. I have a BC6 26 upstairs which I use as a second pair of speaker for parties. When we play NMUSIC through the system there is a slight delay in sound on the BC6 upstairs vs the beocentre 2 downstairs. Sometimes it appears worse than others... Is fine with a CD, RADIO or vinyl..just NRADIO/NMUSIC
Any ideas how to fix?
David
BV8-40, BC6-26, BC2, Beolab 9's, Beogram 7000, Beogram 9500, Beoport, Beotalk 1200, Beocom 6000, Beolit 1000, 800, 700, 600, 400
vikinger
- Posts 2,839
Hi David,
I can only guess that those small differences in processing time that plague modern radio and TV equipment also apply to some B&O units even when they are properly configured to work through a link system (which I thought was meant to eliminate these sorts of problems.)
I managed to download the B&O configuration programme (see Mika's comments above) onto a Windows laptop. It presumably simplifies what you need for linking different units, but there are no explanations. It's like a tool with no manual: you just have to accept the recommendation.
The lack of any further advice in response to my original query makes me think that the majority of us really don't get the best from our equipment, being neither techno experts, nor being prepared to pay a dealer thousands for a bespoke cabled system.
Graham
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
david coyne:
Hello
David
Add "A-N.RA" "A-N.MUS" to your Beo4 LIST and try ..
david coyne
- Sydney, Australia
- Posts 165
thanks Vienna... will try!
Why should this work though?? I'm curious to know why?
David
Vienna
- Posts 712
Video sources have to be delayed in flat TVs to be lipsync with the picture - audio sources don't need a delay.
"AV" + "ANY AUDIO SOURCE" or "A.XXXX" + "GO" are audio commands ... .
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Graham,
Answering your original question, I would suggest taking a look through the BeoTech area linked at the bottom of the main BeoWorld home page. Theres a ton about what goes where and how things talk to each other, should be the perfect resource for you.
EDIT: here, saved you the trouble! http://www.beoworld.org/beotech/index.htm
vikinger
- Posts 2,839
Evan:
Graham,
Thanks Evan. Although I've consulted it before I'd completely forgotten that that area of Beoworld existed!
Graham
david coyne
- Sydney, Australia
- Posts 165
Vienna:
How clever are you!!! Thanks Vienna, seems to have fixed the problem..so easy
When youre in Sydney, the drinks are on me :)
Vienna
- Posts 712
david coyne:
Thanks for the invitation - would be quite a long way round, unfortunately ...
PS: The "AV" trick will only solve delay problems similar to yours - there are other issues causing delays (Dolby, Type of panel/chassis , multiple TVs, ...) that can't be solved in this way!
Page 1 of 1 (17 items)
