Latest post 12-06-2010 7:19 AM by Doogle. 3 replies.
Page 1 of 1 (4 items)
  • 12-06-2010 6:42 AM
    • Doogle
    • Not Ranked
    • Joined on 12-06-2010
    • Posts 3
    Help with Beovox 1200
    Hi folks
    I am busy restoring a pair of two-way Beovox 1200's that someone has messed with previously.
    My query concerns the colour coding of the wiring:
    Purple and white for tweeter
    Red and Black for woofer
    Could someone please tell me which of these are positive and which are negative? They were wired differently in each speaker and I need to get the phasing correct.
    Thanks for the assistance,
    Doogle
  • 12-06-2010 7:00 AM In reply to
    Re: Help with Beovox 1200
    Welcome to the forum!
    If you still have them together with the wires crossed, I believe the wrong one would be rather obvious after just listening to them.
    Alternatively, the negative wires are almost certainly connected together at the crossover and with the negative pole (spade) of the DIN connector. I'd expect the black be negative to the woofer, but there's not much trusting anything if some disorganized person has been in there before.
    -mika
  • 12-06-2010 7:16 AM In reply to
    • Doogle
    • Not Ranked
    • Posts 3
    Thanks, will have a look at the crossovers..... no reference as the wires have been cut with Din plugs removed  :-(
  • 12-06-2010 7:19 AM In reply to
    • Doogle
    • Not Ranked
    • Posts 3
    OK, black and white wires are together at the crossover, with the red and purple leaving after the components! Thanks, solved the problem!  :-) Doogle
