        1st March February 2012
	    Latest post 11-29-2010 5:35 AM by  tournedos. 40 replies.
									        Dillen
								                - Joined on 02-14-2007
								                - Copenhagen / Denmark
								                - Posts 5,008
										    Wonderful piece !
Those resistors are safety components, acting as slow blowing fuses. If they open their solder joint, they should be considered defect and a replacement will be needed.
Having said that, you can of course solder the tab back onto the resistor as a temporary solution but I suggest you put a voltmeter across the resistor to monitor the current flow when you power it up again. If it works and everything looks normal, I will be happy to see if I can find a replacement resistor of the correct type for you.
									        tournedos
								                - Joined on 12-08-2007
								                - Finland
								                - Posts 5,808
										    Thanks, I'll try that, hope I can take you up on your kind offer
   I suppose the normal current at little/no load should be in the
ballpark of tens of milliamps?
I'm in no hurry so I guess it won't hurt if I check first that
all resistors are about in spec. There are no apparently leaking caps.
The only signs of heat are around the power output valves (the PCB has
slightly darkened).
I remember dismantling old radios as a kid and
 had a lot of those resistors... and many of the exact same component
types I see in this radio. I think they have of course been junked ages
ago
Oh yes, the MPX decoder... if I have it, where is it?
There's a suspicious empty slot for a PCB between the power amp and the
speaker connector panel, but I can't see any provisions for connecting
one anywhere.
									        Dillen
								                - Posts 5,008
										    The Stereo decoder is located to the left of the amplifier section, like this:
This particular one is a Dirigent 609 but your 610 is very similar. This one will also need a new pair of output valve sockets. I've found some ceramic ones at Ebay that are very good if you cut the solder pins down to half their supplied width.
									        Dillen
								                - Posts 5,008
										    Check also the output valve grid coupling capacitors. If they are leaky, they will allow DC onto the grid, causing the valve to draw excess anode current. That could cause an overload of the power supply and also the burned resistor. Those caps are normally of a very reliable type (mustard colored dry type) but I have seen cases where they were replaced by something "audiophile" and "modern"...
You have email.
									        tournedos
								                - Finland
								                - Posts 5,808
										    I wussed out, and instead of soldering the fusible resistor together, I replaced the missing connection with a fused ammeter.
Then I powered up - first nothing, but as the tubes started to warm up, the current slowly rose to ~40 mA and stopped there.
I already had a makeshift antenna connected, so I plugged in the S80.2s that happened to sit nearby on the same floor next to my workdesk,
 pushed the inexplicable speaker selectors at random until I heard some
hiss, then started to turn the frequency selector... MUSIC!
Extremely bass heavy, although fixable with the tone controls...
 and then it sounds really good. Cleaning needed at the control pots
perhaps - and definitely at the valve sockets, as the entire receiver is
 extremely microphonic. I will continue with that after it has cooled down and the supply voltages have bled down
Now that I know this works, I have plans for the missing stereo decoder...
									        Dillen
								                - Posts 5,008
										    Microphonics is almost always caused by either hardened rubber insulators where the FM screened can is mounted to the chassis or the front-end valve itself (where a screen or grid may have losened inside the valve in transport or similar). If extreme, as in your case, my bet is on the valve.
(Microphonics is an unwanted side-effect where you can hear what is best described as a kind of hall-effect to the reproduced sound when you tap your finger on the set. Sometimes you can even hear the tap itself as you would on a microphone).
I may be able to document the decoder in my set if that would be of interest.
									        tournedos
								                - Finland
								                - Posts 5,808
										    Oh, I guess I used the wrong term then - it was just very sensitive
to tapping anywhere. I simply removed and reseated all the valves, and
that problem disappeared so it was apparently just bad contacts at the
sockets.
I connected my CD50 to it (how's that for a combo?) and
played it for about two hours straight without any problems, and the
sound is awesome! The boomy bass - I set the knob at about 8 o'clock
before it sounded right - may have flattened a bit, but I'll need to
judge the frequency response better tomorrow... I live in a flat and
can't use any real volume at these hours.
Hold a bit on the decoder
									        Dillen
								                - Posts 5,008
										    A wonderful set, a great thread and lovely work !
The foil on top of the bottom plate is for screening under the sensitive IF circuits.
For the grey part of the dial, I've found a mix of Humbrol colors 129 & 67 in a mix ratio of apprx 10 to 1 to be a fairly good match. Note that Humbrol colors dry up fairly different from wet so make a couple of tests mixes first.
									        tournedos
								                - Finland
								                - Posts 5,808
										    Off to the model shop then! Thanks
I've been playing it all
 afternoon and love it. Might be my new favourite amp for acoustic
music. Even with its mighty 2x4W, it has no problem filling the room
with my passive Pentas, the volume setting halfway up. And I'm sure the
neighbours would agree!
Do you have any theory on the bass issue?
It sounds just as if the bass knob was a quarter of a turn off it's
correct alignment. First I thought it might be a problem at either the
bass EQ network or the "physio" network on the volume pot, but it seems
to be the same on both channels...
									        tournedos
								                - Finland
								                - Posts 5,808
										    Sigh, bliss isn't eternal. While I enjoyed my CDs, the tuner
developed a fault - perhaps something gave due to the heat. Couple of
stations come through everywhere on the dial seemingly regardless where I
 turn it.
Some valve socket problems remain, so I'll clean them properly and redo some solderings.
 Meanwhile, I'm all ears for possible causes for the above... I'm
already looking at getting some spare valves I'll probably need sooner
or later anyway.
									        Dillen
								                - Posts 5,008
										    The bass knob; Is that based on the position on the potentiometers track or the position of the knob ? The thing is, that the knobs have little markers. The markers position differs according to the knobs use. What I mean is that all of the small knobs should be of the same type on your set but a knob from a wrong set could have been fitted at some point, one with a marker 90 deg off.
The tuning fault sounds like an oscillator problem. I think I'd clean valve pins and replace the frontend valve first.
									        tournedos
								                - Finland
								                - Posts 5,808
										    The knob seems correct, the end stops of the travel are where they
are supposed to be. Just that the pot needs to be set at about 8 o'clock
 for the frequency response to sound natural. Not a showstopper, but
there's not much usable range
If cleaning doesn't restore
the tuner I'll get a new ECC85 to try. Already found a local source for
17 euros, which doesn't sound like outright robbery, but I'll shop
around a bit more...
EDIT: a couple of tested excellent Telefunkens coming this way from fleaBay.
									        Evan
								                - Joined on 12-15-2008
								                - Ohio | USA
								                - Posts 2,601
										    WOW.
I want one!
One problem though, I think I like the look of the back more! So nice looking, clean and pefect! I mean don't get me worng - great look on the front too! Hmmmm... would that be hard to use? With the controls facing the wall?
									        soundproof
								                - Joined on 04-16-2007
								                - Posts 2,340
										    Wonderful to see this restored (and saved.)
And I agree with Evman that it looks good both coming and going, so a rectangular mirror behind the unit seems called. for.
									        tournedos
								                - Finland
								                - Posts 5,808
										    All right, despite the best efforts of our strike-ridden postal service I finally got my new valves.
I
 tried two measured good ECC85's in the front end, with practically no
change - a couple of stations are heard on top of each other everywhere,
 with the tuning knob having very little effect. AFC on/off doesn't
change anything either.
Should I still concentrate on the front end, or could it be an IF
 problem? The front end has been boxed annoyingly well and there is no
access to the solder side without removing it...
									        Dillen
								                - Posts 5,008
										    Sounds like it could be allowing both the added and subtracted frequencies in from the mixer or the local oscillator is way off. Alternatively a heavy spurious. Could be an adjustment issue, a too widely tuned LC circuit, maybe even a broken coil, ferrite core or similar but check first anode voltages from the frontend and through the IF stages to make sure that all valves are operating correctly. If you cannot get to the solder side (admittedly difficult in the Dirigent), try finding components attached to the anodes that you can reach from the component side.
Can you tell if one of the stations are correct on its frequency ? If so, can you tell if the other station lies the frequency of the IF higher or lower ?
