Latest post 11-27-2010 3:42 PM by tompa. 1 replies.
Page 1 of 1 (2 items)
  • 11-27-2010 2:22 PM
    DVB HD Module types?
    Hello,
    I have a BV8-40 and this is equipped with the latest DVB HD T/C/S2 module. Now I am considering to buy a BV 10-40/46 and wonder if this uses the same module. Can I take the Module from BV8 and put it into the BV10?
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-27-2010 3:42 PM In reply to
    • tompa
    • Top 500 Contributor
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    Re: DVB HD Module types?
    Heribert:
    Hello,
    Heribert
    It's different module so it cannot be put in the bv10 (same pcb board but different housing)
    if you have a technican willing to order the parts that is different it's possible but i suggest you
    to order bv10 with dvb-hd (some day you maybe want to have it in bv8)
