Latest post 12-16-2010 8:04 PM by Vienna. 3 replies.
Page 1 of 1 (4 items)
  • 12-16-2010 7:17 PM
    Beovision 10 wall bracket installation question
    Hi guys,
    Finally could take delivery of my BV 10 today! Bought it two months ago, but because of the pipe renovation in my building, it's been sitting in my dealers storage.
    Well I got it now. And it looks FINE! Yes -  thumbs up
    It does however only have 2 HDMI. Big disappointment.
    Anyway, the wall bracket, should it be installed at a very slight "leaning angle", since it's sort of like a door frame, and will be "twisted" alot from the weight of the TV channeled all to one side?
    The wall I'm putting it on is concrete/brick so it won't budge much, but I guess 1mm turns into 1cm at 1m distance. So will the wall bracket, even though fastened into bricks and concrete with not less than 12 screws, twist just a tad when I hang the TV on it?
    Thanks,
    Andreas
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-16-2010 7:56 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beovision 10 wall bracket installation question
    Q1: Yes - a very small amount "facing outwards"
    Q2: Yes - use the supplied plastic spacer part(s) as described in the installation manual of your WB
  • 12-16-2010 8:01 PM In reply to
    Vienna:
    What's a small amount? Laughing
    1mm?
    -Andreas
  • 12-16-2010 8:04 PM In reply to
    • Vienna
    • Posts 712
    Big Smile ums a...lecken - if you understand Bayrisch
