Latest post 10-30-2010 8:36 AM by Chrisreunion. 3 replies.
Page 1 of 1 (4 items)
  • 10-27-2010 6:14 AM
    BC9000 strange issue
    Im hoping its something simple like an option issue but there is a slight problem with a Beocenter 9000 I have just got. It works perfectly but when turned off the two green lights for the volume adjust stay lit, they dim, but stay lit. Im sure they should go out. I thought that maybe it was set in option for a particular type of setup but I cant seem to change the option at all. If I try to change the option it just turns on to the radio preset for whatever number I press. Ie Standby, Sound, 1, Store it just turns on radio preset 1. I have tried by going Standby, link, sound, 1 store and the same thing happens. It might have nothing to do with the green lights but you never know. Any ideas anyone.
  • 10-27-2010 8:42 AM In reply to
    Re: BC9000 strange issue
    I can't speak for the VOL lights, but... re: OPTIONS -Beo4? Have you tried A.OPT?
    • B&o bottle opener
  • 10-30-2010 5:20 AM In reply to
    Any one else any ideas.
  • 10-30-2010 8:36 AM In reply to
    How do you set the option on your BC9000? Via direct controls or with Beo4? I would suggest Beo4, maybe not all your keys work anymore on the BeoCenter, who knows. Press std-by+list simultaneously, press list until you see "option", then "a.opt", then the option you want (1,2 or 6 for BC9000), and it should work. As for the volume keys being lit, it's not normal indeed, that's all I can say.Stick out tongue
    Reunion Island is greeting you!
