1st March February 2012
Latest post 10-29-2010 12:51 PM by Doctor. 10 replies.
10-27-2010 12:54 AM
sodoi18
- Joined on 02-06-2010
- USA
- Posts 194
Plan to connect to a beomaster 4500 or 5500. Will use a beolink passive until I get the beomaster.
Which one will be better with above amps. Will be in a basement and mostly play iPod.
What do u guys suggest. I hope to acquire 4500 or 5500 beomaster soon for the beovox.
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
The trumpet stand is more or less the only difference between the 2 types tecnically nearly no difference, check the product pages. the trumpet stand will look good in the basement
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
sodoi18
- USA
- Posts 194
The S45-2 have the rubber rings. What about M70 - Will I run into to the foam rotting issues with M70
sodoi18
- USA
- Posts 194
I want to agree - personally I have not yet heard a S45-2, but read a lot about them
sodoi18
- USA
- Posts 194
Can anyone confirm if the M70 had rubber surround rings
Doctor
- Joined on 09-14-2010
- Posts 555
Completely different design, but outwardly very similar until you take the grilles off! The M70 is almost a monitor class S60 - similar layout but better drive units and a lot bigger. The M75 was almost the same size though a little less deep but resembled the M100 with all the drive units arranged above each other. The M70 also has the stunning trumpet stands. It is interesting to see that the M70 is considerably heavier than the M75 and indeed is slightly heavier than the M100. Suggests that the bass unit has a very large magnet (good!) I have not listened to these two models side by side - could be interesting!
Page 1 of 1 (11 items)
