I have an Attyca 1 which I have been told that I dont need! Its in ok condition with no bubbling or peeling bit does have the odd little knock to the edges on the bottom section. These have been touched up and are not noticable in normal use. It is still a very smart bit of furniture. The top surfaces are fine. The legs are all present and correct.
This is for sale for £110. If you want any images, let me know.
