Latest post 10-23-2010 1:23 AM by Spiros. 4 replies.
Page 1 of 1 (5 items)
  • 10-21-2010 7:15 PM
    Beosystem 3 + Projector
    I have a Beosystem 3 and a Mitsubishi projector.
    The projector is controlled by the BS3 with a trigger that sends an IR to the projector to turn on and off.
    Everything worked well until my dealer did an update on BS3.
    Now, my projector is no more controlled by BS3. I noticed many new menus and configurations options in BS3. I guess there is something to be done here. I tried different ways to control this, but nothing worked...
    My trigger is perfectly OK : the test button sends a good IR to the projector that is going on and off...
    It's just my BS3 that is not sending anything to the trigger...
    Does anyone has an idea to fix this ?
    Olivier
  • 10-22-2010 2:14 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beosystem 3 + Projector
    Hi Olivier, most probably the STB that included your projector has been updated and the dealer did not include it on the update. I would suggest that you contact him to come and include it again.
    Best regards
    Spiros
  • 10-22-2010 5:58 PM In reply to
    HI Spiros !
    Thanks for your answer... but what do you mean by STB ? Cant this be fixed throught the settings of the menu ?
  • 10-23-2010 12:53 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Beosystem 3 Projector
    Hi Olivier,
    Stb is Set Top Box which has all the third party commands (non B
    Best regards
    Spiros
  • 10-23-2010 1:23 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Olivier, Message for some reason was not posted very well. STB is the Set top Box controller which is the includes all the third party commands (Non B&O products) and it should be fairly easy to upgrade once again so that your dealer includes your projector's commands. I think you should try and contact him in order to short it out.
    Best regards
    Spiros
