Latest post 10-16-2010 3:37 AM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 10-14-2010 8:20 PM
    • justw
    • Not Ranked
    • Joined on 07-11-2008
    • U.S.
    • Posts 15
    S60 Crossover components
    I compared my S60 crossover to the schematic in a service manual and find a difference. In the manual it shows an additional RC across the woofer of 37uf and 3.3 ohm and a 47 ohm resistor across the inductor in series with the woofer. This must have been a production change after mine was made. My serial number is: 745070. Does anyone know the net effect of or reason for this change?
    ~W
  • 10-15-2010 3:07 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: S60 Crossover components
    Yes, the woofer type was changed in production.
    You have the late version.
  • 10-15-2010 5:55 PM In reply to
    • justw
    • Not Ranked
    • U.S.
    • Posts 15
    Thanks. Was the original woofer an SEAS also? Curious as to what parameters were different for such modest crossover changes.
    ~W
  • 10-16-2010 3:37 AM In reply to
    • Dillen
    • Posts 5,008
    The earlier woofer was a VIFA M25WN-40
    Later a SEAS 25 F-EW was mounted, requiring changes to 4 components in the filter;
    One capacitor (C2) and two resistors (R2 and R3) was removed and the ferrite core
    of the coil L1 was changed to give the coil more inductance.
