1st March February 2012
Latest post 10-05-2010 4:00 PM by sodoi18. 2 replies.
10-04-2010 7:34 PM
sodoi18
- Joined on 02-06-2010
- USA
- Posts 194
Beolink passive with ML installation issues
I am trying to connect my iPad to the beolink passive via 3.5 mm to power link 5 pin
The passive is connected to RL 60.2. The set up ready but it's not switching on.
Using ir eye to control with beo4
Iam not sure what is wrong. The amplifier worked fine when connected via ML cable.
I want to put this setup in basement with a dedicated iPod. Is there anything wrong?
Do i need a more than 5 pin cable connected from the iPad
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
sodoi18
- USA
- Posts 194
Re: Beolink passive 1658 connected to ipod to RL 60.2- can it be done?
I tried connecting to my beosound 4000 via a beolink wireless and then ML to passive. Also had two
IR eye controls connected to wireless and passive.
I was able to control the beosound via wireless. However, every time I try to switch passive on
Using it's IR the passive switches on for few seconds and then gets into standby.
I have given up working on this tonite. Please suggest how to get the passive provide the sound
To my RL 60.2. Directly connecting to beosound 4000 works but I want to create a link room with
Passive and RL 60.2
I have two IR, iPod to power link, beolink wireless.
sodoi18
- USA
- Posts 194
Updating my own post.
1. I certainly need a mk2 powerlink to connect from the wireless to passive amp.
2. The ML may be not working as its a link(passive) via link(wireless) to the source (ouverture)
If any one out there willing to sell a used powerlink mk2in USA let me know
Page 1 of 1 (3 items)
