I would like to use my BV5 with Beolink Passive driving my BeoVox Pentas in the same room. This is a temporary set-up until I get some active speakers in the new year.
So far I have connected up the BV5 and BL Passive with the Beolink Passinve & speakers using Materlink cable. It works but there is a delay between the BV5 speaker and the BL Passive.
The  other issue is which option to use. (not sure which I'm on at the moment) but to turn on & off I have to have LINK showing in the Beo4, so if I'm watching DTV or DVD then I can control the speakers, but if I want to use my AppleTV which is is controlle using V-Aux I cannot as I have to have LINK showing and then if I go to V-Aux the speakers stay on the DTV. (Update - added the L-V-Aux button and can now control this correctly)
Is it possible to get this working or am I wasting my time! I did read one post where someone said the powerlink socket can be used. ie it makes the speaker "active" in that you plug in a powerlink cable from the BV5 to the BL Passive and you don't use a Masterlink cable and don't need any link eye and it comes on when you use the BV5.
Does that work? I don't want to put anything in that link socket on the BL Passive as the manual says not to. I tried the Config software available on here but it doesn't seem to have Beolink Passive in the Main room.
Stoobie
