        1st March February 2012
									        beodim
								                - Joined on 04-17-2007
								                - Switzerland
								                - Posts 130
										    Re: playback of PC recorded tracks on SD/mmc card in BeoSound 4
										    My BS4 plays all MP3 files recorded with Beoplayer and Windows Media Player and moved to the SD card via BS2.
									    BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
									        The Stig - ver. 1.7
								                - Joined on 06-20-2007
								                - Posts 898
										    Yes...  MP3,   8 kbps to max. of 320 kbps. WMA,  5 kbps to max. of 192 kbps. 32, 64, 128, 256, 512 Mbyte, 1 and 2 Gbyte SD/MMC Tracks must be placed in folders the SD card mustn't be the high speed type(100x)
									        The Stig - ver. 1.7
								                - Posts 898
										    I think it's about 128kbs but I'm sure someone will correct this   If I remember correctly 192kbs is the same as CD
									        Robert
								                - Joined on 06-13-2007
								                - Northern Ireland
								                - Posts 362
										      The Stig - ver. 1.3:Yes...  MP3,   8 kbps to max. of 320 kbps. WMA,  5 kbps to max. of 192 kbps. 32, 64, 128, 256, 512 Mbyte, 1 and 2 Gbyte SD/MMC Tracks must be placed in folders the SD card mustn't be the high speed type(100x)
 Sorry, tracks must be placed in folders? As in, each track in its own folder, or the entire selection of tracks in a single folder?
									        The Stig - ver. 1.7
								                - Posts 898
										      rsmyth:  The Stig - ver. 1.3:Yes...  MP3,   8 kbps to max. of 320 kbps. WMA,  5 kbps to max. of 192 kbps. 32, 64, 128, 256, 512 Mbyte, 1 and 2 Gbyte SD/MMC Tracks must be placed in folders the SD card mustn't be the high speed type(100x)
 Tracks Must not be placed in the Root, as many track you like in a folder, but as I remember there mustn't be a folder in a folder.
									        Robert
								                - Northern Ireland
								                - Posts 362
										    So really i just need one folder with my music in it? Thanks for dealing with such simple questions for me, lol. I'm planning to get a BeoSound 3, and already have an SD card writer & 1gb card, so I want to have a sample of music on SD card to take to the B&O store with me.
									        Dave
								                - Brisbane, Australia
								                - Posts 2,328
										    A folder = album so you can flick through the folders, but it will not play tracks that are in sub folders. You gaet the hang of it. We use an iMac and a card reader to place our music onto the SD, the only thing we had to do was convert the AAC files to mp3, and it was all sorted, it really is very easy and flexible.
								                - Joined on 04-01-2007
								                - UK
								                - Posts 970
										    I use several folders. On my BS3 I think I use up/down to select folders </> to select tracks. I too drag and drop to my SD card reader from iTunes.
        Page 1 of 1 (15 items)
